BCT-15X programming
redbob
Hoover, Alabama
Is there anyone out there who can program my BCT-15X to pick up 800 MHZ transmissions? I'm a lost ball in high weeds with trying to program this beast. Primarily all that I am interested in is receiving Fire Department transmissions. Thank you.
Avery93
AL
Do you have the programming cable and software such as FreeSCAN? If so, I can make you a file with the Jefferson County trunk system and area conventional frequencies programmed, no hiring necessary. :)
Almost all talkgroups on the Jefferson County trunk system are P25 digital, however, so you won't be able to hear them with your BCT-15. Only a few of the smaller fire departments on the system are analog. The good news is most of the fire departments using P25 on the system simulcast their traffic on VHF and UHF analog frequencies. There is also a few that still use VHF/UHF primarily.
In the meantime, you may find this easier to read manual helpful.
nine11diver
Renton,Washington
Can anyone tell me how to change the alabama location that is set by default on the bct15x....i live in washington state and would like to change it...ive looked everywhere and cant find the place to change location!!
W8RMH
Feed Provider Since 2012
Press POL once to turn on a state. Press Function then VOL. Scroll to 'Your State' and press E/ to save and exit. Press POL until all icons disappear again.
Note: District of Columbia, Guam, Hawaii, Puerto Rico, Virgin Islands, and the Canadian provinces don't work in my scanner (??).
Taken from: Easier to Read BCT15-X Scanner Manual menu
puzzleriddle
bham, Bama
if ya talking about any pre programmed stuff that comes with scanner... forget it, its most likely out of date . import the new info from RRDB :), or let someone sent you a file?:)
