BCT 15x question
lbyanks186
Im trying to delete the pre loaded states from the memory of my BCT 15x because I am having problem with it defaulting to them. I tried initializing the memory and it worked but the second part where the directions say it will ask about restoring the factory presets and u can select no that part is not comming up. any ideas how to delete stuff from the factory set up?
lbyanks186
OK thanks, do you know if theres a way you can take them out of the scanning menu? so when your going through to select you systems such as cb air marine ect the state will not be in there? and im assuming its the same with all the custom "1-10" systems you also cannot delete?
UPMan
In Memoriam
Arlington, TX
You cannot delete them. But, it is easy enough to just turn them off if you don't want them.
garys
Texas
Good to know that I had thought about getting a 15X now I know NOT to!
If you lock them out, you'll never even know that they're there. I have one for a few months and haven't even noticed the state frequencies. It's an excellent scanner in it's own right, especially if you don't need digital.
thumper35
i just bought this same scanner and im fairly new to scanning and had a old hand held. now i bought this one and found out there is a bunch of new code instead of entering the 7 digit code there is a easyier way . can anyone help me to understand these new codes and how to input them into the new scanner to avoid entering the 7 digit code anymore for the specifc city i want to listen to
thumper35
no i just need a quick guidance into how to input the new codes instead of enterng the old 7 digit codes the old way.i have had a hand held scanner for many years and now ive upgraded to this new digital scanner and see that there are new code that im not familair with as im use to doing it the old way
scanpprcn
Colorado Springs, CO
Guys, don't give up on this scanner. It is one of the most sensitive scanners I've owned. The flood of options available are truly amazing.
Do we all understand that the ability or not to delete these preloaded state systems has nothing to do with your personal programming options? You can choose to use the preloaded stuff or not. I personally don't use them and they're all off and not in any "system" in my 15X.
It's like buying a new car that comes with some color of floor mats that you just don't like. Don't spoil the deal on the great car for the floor mats. Just throw them in the trunk and drive outta there... Who cares if you can't refuse them in the deal? Besides, maybe someday those floor mats will come in handy...
UPMan
In Memoriam
Arlington, TX
Then you need to start by understanding what those "codes" are. (For trunked systems, you need to enter the system frequencies and the Talk Group IDs for the channels in the system you want to hear.)
See the articles I linked to above.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
As mentioned, Freescan is freeware. The other 2 are commercial. Each has their own strong/weak points and you should try all 3 out to see which one you like.
73 Mike
