BCT-8 Trunking
GTR8000
Well Known Member
BEE00
No, not even close. The BCT8 is an analog scanner. The Loudoun County system is P25 X2-TDMA digital. The only scanner that works on this system is the GRE PSR-800.
DaDruid
Thanks for the info. I will keep that in mind. Novice at this, so I appreciate all the help.
