BCT15 Multi Sites HELPPPPPPPPPPPPP
ScanDaBands
Banned
State Line
#1
ok have 4 sites programmed into one system - all control channel only - NO quickkeys assigned , when I put the system on the BCT15 using ARC15Pro it will not scan the sytem I have to manually unlock each site , then it will scan..........I'm trying to get the the BCT15 to scan all 4 sites - is that possible or am I totally lost on the multi site thing? Do I HAVE TO USE THE KEYS ?
