BCT15 rear panel DB9 connector
Fresno, CA
#1
I can get the front panel serial port to work with the provided adaptor cable, but when I try the rear serial port with a straight-thru cable the radio is not seen.
Do I need a null modem cable? P.46 of the manual is not too clear on this port, and they mention a null modem cable.
My straight thru serial db9 cable works for other uses, but this has me stumped. I can't find a menu option to turn on the rear connector.
Any ideas?
UPMan
Uniden Representative
Arlington, TX
#2
If you are going to connect the scanner to a PC using the rear port, you need to use a null-modem cable. It is configured so that you can plug a GPS's serial cable directly into the scanner w/o an adapter.
Fresno, CA
#3
Yep, I did need a null modem cable. I went out and got one, and all works fine.
I got the BCT15, yesterday. I love it. My other scanners are two BC895XLT's and one BC245XLT. The BCT15 is a big, big improvement over those.
I am using ScanControl Full, as well as ARC15Pro to program it. Of the two, at this time I like ScanControl better.
Thanks for your help!
Mark, K6MAK.
bezking
On the Road
#4
Hey, some other options would be a null-modem adapter, or using CAT5e with DB9 ends on it (nostalgic, heh?). The CAT5e may be a better option for a longer run because you can cut the cable, put an 8P8C (RJ-45) end on it and attach the adapter.
