bct15 reset
radioman1974
Hi all im in the uk and have just recieved my bct15 sitched it on all is well its a great scanner,but how the hell do i get rid of all the us police frequencies that are pre programmed in the set? ive done a reset but this didnt help,and im totally baffled on how to do it,maybe its beacause its new to me,but i had no problems with the two 246ts i own.
radioman1974
I was under the impression this couldnt be done,the frequencies were put in at the factory,when i go into programme there are no systems as they are already in the radio,not stuff ive put in myself,i was going to buy the butel software as i like the ease of use.as i already own a couple of uniden radios.
AG4WI
Middle Tennessee
You can delete the pre programed Freq. by doing a reset But the Beartracker Freq,s programed for each State is programed in at the Factory and cannot be deleted!
At least i have not found a way to delete them. I just turn all them off.. Your 246 does not have the Beartracker function in it like the BTC15..
RadioFreq
Burlington, CT
BCT15 Reset Procedure
Warning: Before proceeding, you may want to make a backup copy of the data for future use. The following is the reset procedure:
1. Turn Radio Off
2. Press & hold down the following 3 keys;
number 2: number 9 and the Hold button.
3. While pressing and holding the above keys, turn radio on
and then release the keys.
After a few seconds, you should have a complete reset.
Hope this helps.
Brian
wesct
Connecticut
1. Turn Radio Off
Hope this helps.
Brian
While that reset procedure does clear out any troubles with the radio, it will not
erase the pre-programmed systems in the radio.
I would think that someone forgot some code in the firmware.
wesct
UPMan
In Memoriam
Arlington, TX
The BearTracker frequencies (BT, PL, HP, DT) cannot be modified or deleted.
