Bct15
connecticut
#1
hello can any one help me i tried to get the latest firmware and now my scaner is now with a blank screen and it blinks and nothing happens even when i turn it on and off all i get is a blank screen and blinking please help
Indiana
#2
You need to try to install the update again. Using BC_Vup, be sure you follow the instructions to the letter. Sounds like you didn't unplug the power supply and hold the HOLD / RESUME button down while you plug the power back in . Hold the button down until the display stops flashing.
Indiana
#6
Turn scanner off. Press and hold in 2 , 9 , HOLD keys then turn the scanner back on. Wait until ALL MEMORY is CLEARED. Then select "Yes" or "No" if you want to re-install the Factory Pre-Program List.
Indiana
#9
Apparently you interrupted the progress of the upgrade before it was finished. Hook the program cable up again and open the BC_VUP program and locate the Update file again and try to re-start the update again. Be sure to follow the instructions closely.
Ames, IA
#11
Your only real hope is to follow the instructions exactly to get the firmware to update or send it to Uniden for them to fix the problem.
Indiana
#12
I doubt that you have shorted anything out Are you using the latest BC_VUP that is currently on Unidens Website? I have done updates successfully on several scanners and I know it can be confusing when something doesn't go right. I would contact the place where you bought it or Uniden as a last resort. If you would like to contact me, PM me your e-mail address and I will send you my phone #.
