BCT15X: BCT15X Alert Light
BobW55
Sanilac county Michigan
I have several frequencies programmed in where I set the alert light to FLASH RAPIDLY.
I thought the little alert light above the volume knob would flash. What I am finding is the back light in the display flashes.
Is this normal? Not really spelled out in either manual.
bobruzzo
W1AV
Cranston, Rhode Island
That alert light is for when you are using "close call" and radio finds an active freq. Then that light flashes. Yeah that backlight flashing is annoying so I dont bother with any of that.
BobW55
Actually right now I like the Display lighting up. I have a bunch of Air and MilAir frequencies I am trying out so it helps me see I have a hit.
bobruzzo
W1AV
OK thats cool if it benefits you. I think it would be cool to be able to assign different colors to different quick keys.
JoeBearcat
Uniden Representative
On the 15x there are 7 colors available for the visual alert (or OFF).
JoeBearcat
My mistake. I apologize. I thought I was looking at a BCT15X when I was actually looking at a BCD996P2. (both are black units)
eorange
♦RF Enabled Member♦
Cleveland, OH
On the BCT15X...SET ALERT LIGHT per the above menu navigation only has these choices:
Off
Slow Blink
Fast Blink
drdeputy
N Central FL/SW Missouri/Central Iowa
I don't have a BCD996P2 . I have 3 other digital scanners, needed an analog unit.
I'm in the same boat with a 15X....I just got it to use only for analog (rail, air, etc) and I continue to be baffled by the Alert LED. Does it only work with Close Call and Bear Tracker function? I likely won't be using either of those. The various programming software I've tried (at least FreeScan and ARC) happily let you choose colors, but it apparently doesn't work that way...! <sigh>. And yeah, the flashing screen route doesn't work for me either.
BobW55
Yes only with those functions. For everything else, the display lights (Backlights) flash, or turn on depending on the mode chosen.
