BCT15X C-CH output
Cognomen
Radioactive Zone
From what I've read, the BCT15X has the equivalent of a discriminator tap in the C-CH output.
However, I've been unable to find out exactly how to access this data.
The intent is to feed Unitrunker with the raw audio from a tapped PRO-2006, then have Unitrunker control the BCT15X frequency. I then need to output the raw audio from the BCT15X to a computer soundcard.
Anyone know off-hand where to find the raw audio?
ProScan
Software Provider
Ontario, Calif.
There's no raw audio output or discriminator tap. The C-Ch data is streamed out of the RS-232 port in a text message format.
Cognomen
Radioactive Zone
Okay, I opened up one of the new BCT15X's here and the discriminator tap point is clearly marked on the PC board located at the top side of the radio.
Remove the outer black case.
Remove the grey metal inner top case.
Locate the tap point marked "DISC" approx 1" down and to the right of the center of the board.
I haven't even powered this one up yet and I've already opened it. lol Will verify that the radio works before I start soldering.
Thanks Uniden for making it easy.
