Setting the Serial Port Speed
MENU
Settings
Set Serial Port
Set Baud Rate
Set Front Port or Set Rear Port
Use this setting to control the data rate used for the front and back panel serial
ports. You typically set the front port to match the speed used to communicate with
your PC (default 115200 bps) and the back port to the speed used to communicate
with an attached GPS (default 4800 bps). Note that the back port is male. You may
need a gender changer and a null modem adapter to use a typical DB9 serial
cable from the rear port.
For Serial Port Speed (Baud Rate), select from
4800 bps
9600 bps
19200 bps
38400 bps
57600 bps
115200 bps
OFF
Set Serial Port
Easier to Read BCT15-X Scanner Manual serial port
Set Serial Port allows you to set the baud rate for the front and rear serial ports. You typically set the front port to match the speed used to communicate with your PC (default 115200 bps) and the back port to the speed used to communicate with an attached GPS device (default 4800 bps). Note that the back port is male. You may need a gender changer and a null modem adapter to use a typical DB9 serial cable from the rear port.
