BCT15X Help
wfrancis16
Hudson, MA
Is there a way to lock the keypad on a BCT15X? The only thing close to that I have found is the Key Safe mode. The problem that I have is that the "POL" and "HP" buttons keep getting pressed and others guys using the scanner do not understand how to get back to the normal scanning operation.
Minus1
UK
POL & DOT use the frequencies set for your state [Func Volume]. I am in the UK so frequencies for all states are irrelevant. Fortunately, I discovered that there are NO frequencies set for 'Ontario', so I set my BCT15X to that. End of problem.
The firmware on my two BCT15Xs is 1.03.00 and 1.03.02.
I can't guarantee this technique will work on all BCT15X's :)
wfrancis16
Hudson, MA
That was it!!!!! You have no idea how long I have been trying to figure out a solution for that problem. Thank you very much.
