Firmware for your scanner
The Uniden Web site instructions aren't too clear. The Web site says:
These are the installation Steps from the Uniden Web site:
Download BC_VUP3 Firmware Updater for DMA Scanners, unzip the file, then run the installer to install this utility. Then, run the utility and follow the on-screen prompts to select the scanner model and firmware version to apply.
When I unzip that folder, I see a folder labeled
BC_VUP_V3_03_00. Inside that folder is a setup.exe file and a Setup_BC_VUP.msi file.
The only reason I selected the
Setup_BC_VUP.msi file is because it was the closest match to what the instructions say to select:
Run the BC_VUP3 utility (not the .msi file).
It would have been nice if the instructions mentioned selecting the
Setup_BC_VUP.msi file rather than to
Run the BC_VUP3 utility.
I think it would be a bit clearer for people if it read:
Installation Steps-
Download and unzip BC_VUP_V3_03_00.zip. Find the extracted files and open the BC_VUP_V3_03_00 folder. Click on the BC_VUP3.msi file, select Install. Once the utility is installed, go to your Start Menu and select BC_VUP3 to run the utility and follow the on-screen instructions.
And once this utility is installed on your computer, it doesn’t need to be downloaded for future firmware updates. Some people don’t realize this software only needs to be downloaded once.
To upgrade/download any future firmware is done by running the BC_VUP3 software right from your computer and follow the instructions.
