I would get the usb1 cable if you don't want any hassle. You can also look for a usb to Serial cable and use the cable that is included but depending on your skill set it can be a pain.I linked a couple of sources for the cable below.What do I need for programming cable, I have a newer Windows 10 Alienware desktop
Sent from my iPhone using Tapatalk Pro
The 15x is a solid well built analog scanner I highly recommend it.
So I’m looking for something that will do good on local VFDs, I know they are not digital. Would this work good for Hardin county Texas?
TxScanner, The Bearcat BCT-15X is a GREAT analog scanner. You can order it from Bearcat Warehouse in Maryland and their number is 877-568-7226 and tell Paul that I recommended you. They ship fast and have FRESH stock.
Hope this helps you sir.
KR7CQ-You are 100% correct on the "GO TO SCANNER". Only thing bad about it is no instruction manual and not a current computer cable. Anyone purchasing this MUST buy the other cable that the BCD-996P2 comes with and all the rest.It's the best reasonably modern analog-only scanner you will find. I use BCT15X's for the bulk of my analog work, and then I have specialized / older scanners that allow me to dig the weaker stuff out of the mud a touch better than the BCT15X can when needed. For instance, the BCT15X can't match my PRO-2006 on UHF, but it's close enough for most work, and it allows me to not hear CW station identifiers every 30 minutes on a half dozen different frequencies. The BCT15X is the go-to analog-only scanner for typical work.
He has digital scannersIf you look at our county page, and go to the bottom;
https://www.radioreference.com/apps/db/?ctid=2622
you will see the trunk systems in use in your area. It appears your current trunk system is gradually migrating to a Phase 2 system, which the 15x can't handle. Buying a P2 compatible scanner now is probably a wise move in case your area does decide to go that way. You can find the compatible models here under 'Scanner support for TDMA'...
https://wiki.radioreference.com/index.php/APCO_Project_25
Phase 2 scanners work just fine with analog systems, so you would still be covered....Mike
Serial cable and a null modem adapter.I found a protocol manual and the easier to read manual both for the 15x by doing google search plus the original bct15 manual in .pdf format what else would you need control mine using the back 9 pin serial port on a dell desktop running win 8.1 with a real serial port not usb.
Glad you got it. Enjoy it as said before it is a great unit.Thanks for the info, i ordered the scanner and cable i needed, appreciate the info
Sent from my iPad using Tapatalk Pro
