BCT8 help needed (Worcester MA)
Lowfront
I wanted to start using my older BCT8 radio to listen to Worcester POL and my old settings aren't working. I can't figure out why this is happening because it previously worked. State police still scans correctly that I manually setup years ago.
Has there been an update to the radio or anything? I assume no because its so old now.
Thank you!
kruser
Well Known Member
W St Louis Cnty, MO
Lowfront
n1chu
Farmington, Connecticut
Give Scanner Master a call. You’ve got 4 handheld scanners available from Uniden that will do Phase II. But Scanner Master has been around for many years and are knowledgeable on what you need and how much to spend. You can check out the Home Patrol 2, the BCD326P2, the BCD436HP and the SDS200 on their website.
