BCT8??? Help?
csvt17
Hi Im new and just got a BCT8...I programmed all of Livonia's Fire Radio Frequencies into Bank 1 all in the correct order...
I then programmed all of the AFS numbers that I want to hear into each of the radio frequencies...
Ill hit "search" and it displays "ID Scan"...and I dont hear anything at all...no talking as of yet, and Ive had it for 5 or 6 hours now.
Did I do something wrong programming the numbers? Or is there another search option?
What I wanna do overall is scan all of the AFS numbers I have programmed at once, so I dont have to keep manually going through and doing it...SOMEONE HELLLP!!
