BCT8 Windows7?
JBE
Harrison, Mi.
I recently had to upgrade my laptop from a Windows XP Machine to a Windows 7 amchine and I had to upgrade the USB to Serial cable also for 64 bit. I cannot get my new equipment to see the BCT8 scanner anymore? Anyone had anysuggestions or am I using the wrong serial cable?
Thanks, JB
kilowa22
Oregon
Did you install the correct driver for Windows 7 64 Bit? With the USB device unplugged from the port install the USB Serial port driver, reboot, open the device manager and plug in the USB serial device. A COM port enter should appear in the device manager, click the + box and the COM port number should appear.
If you see a yellow question mark in the COM port section the driver is not working with Win7 64 bit, check to make sure you have the correct driver.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Win 7 64 bit drivers aren't easy to find; I understand not every distributor is making them...Mike
JBE
Harrison, Mi.
Thanks so much for your quick reply I have been using the USB adaptor on many other applications and working fine. I may not have the proper cable for the scanner I have tried both a straight through and a null modem cable but still no luck? I can get the alert function and light to sound when I click on upload but thats it I still get a message that it doesn't see the radio?
Still trying, JB
