bcTool or Free Scan
jschandua87
Pearsall, TX
I have both of those programs and just want to see which one is better? And also when I try to connect to com port 3 it dose not work and I can not change the port so I am not sure why. I have a BCD996T and have the USB cable and download the drivers,
satosi
Southern Ohio
Are you sure that the port used by Window for your USB cable is COM3?
Also if you go into the advanced settings for the device in device manager (Under Ports), I am pretty sure you can change the Comm. port assigned to the device.
jschandua87
Pearsall, TX
Ok I will look at it later but just find out I did not have the right driver install I have windows 7. And I look and when I pull down the bar they is only had com3. And is free scan a good one to use?
WAScanMan
Thurston County, WA
I prefer bctool for unattended logging due to the auto lock out feature. Free scan imo is better for programming. Give them both a shot since they're free and see how they work for you.
wmbio
Cumberland, Md
My Dell uses comm port 5 for the usb connection to the scanner...try that.
enjoy
wmbio
