Beachwood Mall DMR
Hummer8290
Looking for info on the Beachwood Mall DMR system. Dosent seem to exist within the database.
n8jsw
Ohio
If you are talking about Beachwood Place try these but use tone search and it should find the info you need
464.52500 469.52500 WQAF892 RM77.0 PLBeachwdPlaceBeachwood Place - Mall Ops FM Business
464.97500 469.97500 WQAF892 RM732 DPLBeachwdPlaceBeachwood Place - Security FM Security
BEACHWOOD PLACE WQAF892 462.30000 2014-03-12 A 20 0 MO IG BEACHWOOD
BEACHWOOD PLACE WQAF892 463.62500 2014-03-12 A 1 0 FB2 IG BEACHWOOD
BEACHWOOD PLACE WQAF892 464.46250 2014-03-12 A 1 0 FB2 IG BEACHWOOD
BEACHWOOD PLACE WQAF892 468.62500 2014-03-12 A 20 0 MO IG BEACHWOOD
BEACHWOOD PLACE WQAF892 469.46250 2014-03-12 A 20 0 MO IG BEACHWOOD
Hummer8290
Yes it is Beachwood place. Back in the spring of 2019 the mall upgraded from analog, to DMR digital radios, I needed info such as talk group ids and colour codes.
n8jsw
Ohio
if you are using a scanner with DMR put in the frequencies in and have it search for the info cause when it stops on a active frequency it will show you the info for it if it is a DMR frequency
Hummer8290
Do you know of any cheap Dmr scanners
wa8pyr
Staff member
Lead Database Admin
Ohio
No such animal. You're looking at several hundred $$ for a scanner capable of DMR, unless you can find one used for a bit less.
n8jsw
Ohio
you can get a uniden bcd325 handheld for around 325-350 i believe
Hummer8290
I will see if I can get a hold north coast two way, they supplied and programmed the radios. It’s for work, so if I need too I can get to the malls security office
TV88KEYS
Cleveland Ohio
Hummer8290
Thanks for the response, I work up there as a side job so I need something to keep in touch with the mall
Hummer8290
I ended up purchasing Mototrbo CPS. Everything is set up, it seems that they changed some of their frequencies.
