Beacons
#1
What is a good radio to receive beacons on and not high in price. My Tescun is not the best at all.
DOCTOR/795
woebbers
Valley Forge Pa
#2
I use an Icom Ic-R7000 and it does a good job...most problems people have is trying to get passed the noise. Oh and I'm assuming your trying to receive beacons under the MW band like below 500 Khz. The radios are around for around 300 to 500 depending on condition. Hope this helps
Sal
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
#4
Part of the problem with some receivers - and ham transceivers too - is that the sensitivity below 1 mhz is deliberately reduced (sometimes with a pot or resistor...) to reduce overloading issues. Depending on how the RF deck is designed, that might also hit the LW band as well.
Now that applies to LW beacons - there are many beacons on HF as well (outside of the usual ones found in the ham bands) that many assume are for propagation studies, although there have been other more unusual apps that have been suggested...best regards..Mike
