Bearcat 880 PA speaker
slowmover
Fort Worth
It’s a rabbit hole.
No E-Z location to mount horn.
Needs an amp.
Then, there’s the wiring.
And, not a CB where, mobile context of use, is what matters above gear. That which most may never gain in sufficiency. Radio rig thus framed is more easily understood, locations chosen, and use delineated.
Using one while all is going pear-shaped at over 60-MPH is not the time to find out bad choices were made re gear & mounts.
Why this linked thread exists is as a shortcut:
Public Address to tell those blocking a Portland road to move, or else, . . . .
slowmover
Fort Worth
I wouldn’t call it a pain if a good location for the speaker horn is found.
The rest is detail. A plan, laid out.
Police vehicle is the model to follow. GALLS and others for current equipment. eBay if you take the time to search for auctioned gear.
Where located on today’s tighter underhood confines vehicles (Charger, etc)
The CVPI Ford used 1992-2006 or so is another.
The assumption is that you want to be heard.
Hood closed, engine-running, and in traffic.
I’d have a helper in another car before permanent mount. Just the downward angle of a fenderwell mount may need to be changed. Search for photos.
It’s easy to mount one behind a brush guard, but that may not be desirable. “Hey, you! Yeah, you, the stupid one . . , “
slowmover
Fort Worth
Vehicle-specific mounts.
GROTE is trusted HQ truck supplier of lighting products.
So, at this end — with cab-mount control box — is the $$ way to go.
slowmover
Fort Worth
Literally, I’d try something like these and see if it works out; it’s what I’ll do on first go-round.
1). On vehicle metal fenderwell aimed at radiator can work.
2). Same for across front of radiator crossmember (behind grille).
3). Off windshield cowl aimed down.
I’ve installed car horns in all these locations.
If you can fit the horn for non-interference then a bracket can be cobbled up.
slowmover
Fort Worth
No traffic, wind or engine noise. “Other person” is outdoors, not in vehicle in traffic with A/C on.
arcanemirage
Portland Oregon
Thank you so much! This helps a lot!
arcanemirage
Portland Oregon
slowmover
Fort Worth
The quality of installations is low. Do better.
I “think” the CB audio can be patched in on some type control heads. (A pair of white wires on one of them).
n3obl
ØAES-1024
PA
You do not want an emergency vehicle speaker. That is not what you use for the CB PA feature. Those are for 100 watt emergency vehicle sirens.
That CB PA feature is probably 10-15 watts and you need a PA Horn speaker.
