Beeps
Paragould/Greene County AR
#1
I know I just posted a thread but I didn't want to hijack it so I started a new one.. There is a setting on the analog and digital side of my PSR 500 that will let me set a certain sound (BEEP) at each transmission.. I have set them on and tried different ones, It will not do any of that, Can anyone explain why? Does there have to be a certain type of P25 system before it will work? I've tried it on SEVERAL different systems/frequenies digital and analog, Can anyone say why it won't work? Just curious..
mikey60
Oakland County Michigan
#2
What is your sound mode set to in the GLOB menu? If it's set to stlth you won't hear any sounds. Set it to On to hear them.
Mike
#3
Mike
Ok I found it under sound mode and it is on, Here's one to figure out, I have V folders enabled on this one I can't hear them but on the other on I was on earlier today, I can, Why is that? It's set to on, Should I erase it and start over?
I got it.. It wasn't in the sound on/off sound.. It was In the ALERT MODE it was set to LED and should have been on BOTH.
