Belkin F5U109 USB to serial adapter
Muskegon, Michigan
#1
I have a Uniden BCD396T and 1 serial port that a UPS is hooked too...
I have a USB to Serial adapter that I would like to use in WIndows 7 x64 but Belkin does not have hany drivers for x64 anything....
Anyone get this working in vista/windows 7 x64 yet? If not what cable do you use and where do I get one?
wbigcount
Kansas City
#3
My uniden Serial adapter wouldnt work with vista at all. I installed windows 7 64x and it worked right away, didnt have to install drivers or anything it found it on its own. I think it is the PL2303 chip set also
#7
The only good USB to Serial adapter I have found is from U.S. Converters. I have been using the PRO version with Windows 7 64-bit for several months now without any problems. Highly recommended.
