Bell FleetNet - Site 20 Windsor
mciupa
DB Administrator
Moderator
As a courtesy, I want to alert the membership that on site 20 Windsor the alternate control channel status on 143.145 was removed. You may wish to adjust your programming accordingly.
This is why there is a green highlight for FleetNet Zone 1.
exkalibur
York, Ontario
I also noticed that there's a control channel listed for the Cedarwoods site as 143.805. This is impossible as the radios don't have any control channels above 143.145 programmed in them. Is anyone within range of this site able to run TRUNK88/Trunker and see what the proper Alternate Control Channel is?
slicerwizard
Toronto, Ontario
That doesn't stop the radios from adding the frequency to their almanac when a site broadcasts it as an ACC or neighbour PCC.
Code:
21-Sep-2013  15:01
  Neighbour List for 782D zone 3 (Cedarwoods)
   SysID  Zone  Alias   ----PCC-----   Zone Name
    782D   02   02GLPH  487 (142.620)  Guelph
    782D   04   04LIST  467 (142.320)  Listowel
    782D   12   12WDLN  519 (143.100)  Woodlawn
    782D   21   21WSTK  463 (142.260)  Woodstock
    782D   23   23BRAN  426 (141.705)  Brantford
    782D   33   33STRT  522 (143.145)  Stratford
  Current zone ACC: 566 (143.805)
exkalibur
York, Ontario
The problem with it as a possible PCC though is that a radio being turned on in an area where that is the only site it can hear, will never get the tower, as it wouldn't have the neighbour list. Then again, the 32 control channel limitation isn't there anymore, so newer radios being added wouldn't care.
slicerwizard
Toronto, Ontario
Are the radios programmed to revert to full band scans? Would solve the problem...
