melonman07
I have broken the beltclip from my Pro-668 . I would like to have one for the radio. Thanks for any assistance.
Kevin
Kevin
When Whistler gets done with their new website you can buy the old style or the new style like the 1088 has on it...
The belt clips are now listed on the new Whistler website: https://whistlergroup.com/collections/scanner-accessories
Also as Whistler has already posted here on RR, you can use the code "SCANNERSHIP" at checkout to receive FREE shipping on your scanner accessories until August 31st. Per the fine print of this offer: "Limit one coupon per customer. Valid on standard shipping up to $10."
Was looking at the 'swivel' beltclip accessory, how does this mount to the PRO-668 scanner? Not enough info on the site. Is it a total back (top) replacement (4 screws out, replace back, 4 screws back)?
...I've placed my order...
Kevin
From page 11 of the Whistler WS1080 owner's manual (same scanner as the Radio Shack PRO-668) this is how you install the swivel belt clip:
"Swivel clip allows the scanner to move
with you and easily move it out of the
way without unclipping it from your
belt. To attach the Swivel clip to the
scanner; align the belt clip grooves to
the slots on the back of the scanner.
Slide the clip down until it clicks in
place. To remove the belt clip, pull
back on the small tab and slide the clip
upward."
The full owner's manual for the Whistler WS1080 can be downloaded here: https://cdn.shopify.com/s/files/1/1420/2702/files/WS1088_Manual_12D15.pdf
