Bennett S/F
#1
ACSO has quite a few units on the way to a "fully involved" barn. I can't hear Bennett fire, can anyone else?
Somewhere in the Rocky Mountains
#2
Bennett Structure Fire
Hello cstockmyer
This fire is actually in Byers. Byers and Strasburg has several units enroute, Bennet has not sent anything. I believe that Strasburg is using Bennets talkgroup. Per 701, this was a barn and grass fire. I'll post more when I check our logs.
*UPDATE* The fire location was 2350 S. County Rd. 185.
Frank
#3
FiremanSparky said:
Hello cstockmyer
Frank
Thank you Sir!
