Berkshire County tones
D
DaveNF2G
Guest
I have made great progress toward identifying the fire/EMS paging tones on Berkshire County's main fire dispatch channel. There are some gaps, though. Many of them are because the dispatchers either mumble or fail to key the mic before they start talking. Anyone near the western end of Mass. who can help fill in the blanks, please take a look at my listing and let me know what you can add via feedback@nf2g.com .
The list is at http://nf2g.com/scannist/statewide_tones.html
Thanks in advance for any help.
N4UYV_Al
Western Massachusetts
Ya know, I use ta know them in my head when I worked there but everything's changed now.... I'll see if I can fill in the blanks & get back to ya Dave.......
UPDATE-
I think Blandford is missing (would be on Monday's test).... Florida Fire is missing, Hanesdale is actually Hinsdale......Hancock has station#1 on Rt.43 (North) & station#2 on Rt.20 (South)....Tuesday's unknown #1 is probably Housatonic Fire....Wednesday's Unknowns 1,2 & 3 might be Monterey Fire, Monterey Car 1 (those are missing)...
Friday's #1 & or #2 might be Tyringham Fire (they're missing) & Tolland Fire is missing from the list.....Friday's 3,4, & 5 & unknowns a & b (not specific) are the county dive team, Berkshire Mountain Search & Rescue & a few others I cant recall right now but I'll give it a listen....Also, Pownal Fire Dept in southern Vermont is also dispatched by Berkshire County but I cant recall where their list is in the rotation....
D
DaveNF2G
Guest
I got two of the Wednesday unknowns tonight. #1 is Middlefield & #2 is Monterey. #3 is still New something garbled.
The last dispatcher who tripped Hinsdale pronounced it Hanesdale, which is why I changed my listings. Not only do they not use the radio very well, but apparently some of them talk funny.
D
DaveNF2G
Guest
Heheheh.
Thanks for the additional ID. It sounded like he was saying "New Ancient" or something.
GBFD10
MA
Your Tuesday Unknown is Housatonic (Part of Great Barrington FD)
also your S. Berkshire amb tone is only used to trip a pager at the dispatch center in GB, who inturn dispatches the amubulance on 155.775 w/ a differnet tone (i can try and find it)
Sheffield is tested on Mondays by Great Barrington Dispatch, duno if you can get them over in Guilderland (we can hear you guys loud and clear here...lol)
As for the friday unknowns, the set of 3 tones that is tested is the Berkshire County Dive Team tones.. ... if i can set up in time tonite, I will try and record the friday tone test for you (if they remember to do it). Also tested is the fire coordinators pagers, and a few departments.
Also.. mising from your list - Florida FD, Savoy FD,
Car 849 (ambulance?) - 849 is the Great Barrington Dispatch call sign (KCB849) duno where you came up w/ car 849..lol
D
DaveNF2G
Guest
Thanks for the ID on Housatonic and the info on the SBA tone.
I've never received SB Dispatch, so I probably wouldn't hear their test. :-(
I tried to record tonight's test and got no audio, just silent files. Can they turn off PL when transmitting?
(I missed Thursday this week because I forgot to plug in the scanner and the batteries ran down before the test.)
I'll add the missing ones so I know there are more to discover.
As for the "car" 849 - I heard 470 set off pager tones and call 849 about an ALS intercept. As there are ambulances with numbers ending in 9, I thought it was one of them. I don't know Berkshire County's numbering system, so....
BTW, I heard someone asked to switch to "385" which I assume is 155.385. I didn't hear anything on that frequency, so I'm guessing it's for mobiles. Can you confirm?
I've heard 155.775 and the City of Pittsfield FD from the car at times, but never from home. I'll set a scanner on 775 for a while and see if anything comes through.
GBFD10
MA
Ahhh lets see... The ambulances that end in "9" are gonna be AMR rigs out pittsfield, for example - AMR 459. "849" (154.310) and Great Barrington "Central" (155.775) is the same person, diff freqs. Chances are, if you heard an ALS request given to 849, it was either for the towns of W. Stockbridge, Sandisfield, or New Marlborough. SBVAS is the primary ambulance co for Great Barrington, Egremont, Sheffield, Monterey, Mt. Washington, and Alford, as well as certain parts of W. Stockbridge, and Stockbridge. (SBVAS is toned and operates on GBPD Central 155.775).
As far as I know, there was no test tonite, I was workin in my parents backyard but I did have my pager open and I think i had a scanner outside, and I didnt hear it... They do tend to skip them often, espsecially if there is a call or 2 going right around 6.
You are correct about "385"... It is used as a secondary means of contacting the hospitals (155.340 is the main channel used AKA "340") Ambulances have to dial into the hospitals to talk to them (I konw the DTMF Codes if you want them). Mostly 385 is used for coordinating ALS intercepts between the two rigs, however when 470 gets really busy, they will switch EMS calls over to 385 as they have the ability to both monitor and transmit on that channel.
GBPD central transmits off of Fairview Hospital, so the signal doesnt get out very well, especially to the north (I have heard them as far south as the Bronx though). When they transmit on the fire channel as 849, they are transmitting from the top of the mountain that Butternut basin is on, so they get excellent distance and coverage. I heard a number of calls go out from them while i was at college in Rindge, NH.
OK enough rambling... Let me know if you need any info at all from this area, I've got most of it figured out, and (sadly) memorized most of the freqs, etc... I;ll work on getting the tone tests next week recorded (including GBPD's monday test (all kindsa pagers, dont know what half em are used for)).
D
DaveNF2G
Guest
I wonder if there were complaints about the test, then. I'd bet a lot of pagers didn't go off if they have PL in them. As I said, the vox circuitry was tripped on my scanner and software, but no audio was recorded. This happens when I'm in manual mode sitting on a PL'ed channel and something with a different tone is received. The speaker stays muted, but the receiver "knows" that there is a signal. The pattern and timing of transmissions between 18:00 and 18:10 was almost identical to last Friday's pattern, minus the audio.
GBFD10
MA
Fire pagers are incabable of decoding PL's, so there wouldnt be a reason for them to not transmit using the PLs... In my 5 years of living here, they've never done that... You likley are picking up Middletown, NY which is also on 154.310 (all sorts of far-away stuff was coming though yesterday, including FDNY here in GB). Either way, they did not do a tone test last night... duno what you 'heard".
N4UYV_Al
Yeah Dave, If the county fire mutual aid center has alot of activity on the fire or county police frequency, they will delay or cancel the tone/pager tests.. Back in the day, we were instructed to do them at a later time in the evening if there was alot of activity but alot of Fire personel were getting ticked when they had ta jump for the door at 8 or 9 at night for a test that was supposed ta be at 6 so we wouldnt bother at all...Pittsfield has ALS Medic units 81 & 82(for County Ambulance Service) & Medic 91 & 92(For AMR Ambulance) both our private contracted ambulance companies for the city of Pittsfield that provide ALS for volunteer towns if needed & then, as Sam stated, may use ID's such as AMR 459, County 809,etc,. Oh yeah, the County Communications center does not (That I know of) have the ability at the consoles to disable their transmit PL tones...Note: I use ta love turnin off the receive pl's on a quiet 3rd shift ta listen to Hartford City (CT) fire & Everett,Ma Fire near Boston....amazing what you could hear with 4 or 5 mountaintop antennas all tuned on 1 frequency.....
D
DaveNF2G
Guest
As my website is directed to New York users, I'm just trying to capture those tones that could be useful to people in New York State. I can hear 470 all the way to the Helderburgs. The other local transmitters just don't make it over the line.
I appreciate the thought, though.
