dmg1969
I scan primarily VHF low, VHF high and UHF...nothing in the 800 MHz range. Particularly, I want good performance in the VHF low range because that is what my county police and fire are on. So, i guess I am looking at something that will run the gamut from 25-1300 MHz.
I would prefer to mount it in my attic, but am limited on room. It is a ranch house and the only thing up there are the roof trusses. I have not measured, but can't imagine that there is much more than 4' of vertical room at the peak. I was thinking about an unbalanced dipole, but that has the be mounted vertically if I'm not mistaken and it would not fit.
My main reason for wanting to attic mount is that I would be concerned about grounding issues and lightning if mounting outside. IF I would mount outside, I would just go with piece of mast attached to our deck. In that event, I guess I could go with either a discone or a Scantenna. How does one ground an antenna installed outside? I have seen coax that appears to have a grounding wire attached. Is that what I need and just run that to a length of rebar pounded into the ground?
Dave
Dave
