fatsuckertim
We have a 50-60 ft tower beside a large metal building that houses our offices and buildings. Years ago we had a kenwood trunking base radio and had a short yagi and a CB antennea mounted on the tower. We monitor Mo Highway Patrol Troop A as we sit next to the highway.
I have a 996 P2 and a 996XT, one hooked to the old yagi and one hooked to a scanner antenna, which has one whip straight up and whips below that pointing down like a cone. (Discone?)
I split the MOSWIN towers for troop A between the 2 scanners. Pick up the Daton/Aaron tower mostly as it is the closest, appears to be the busiest too.
One coax says " International wire and cable co #9091 RG 8X " on it and the other looks to be the same diameter but cannot identify it. Probably a 120' run.
What is the best coax and antennas I should use? I know MOSWIN has some 700mhz towers and the others might be in the 100-200 range.
I know that both coax's are 25+ years old.
Any recommendations?
PS- we always monitored Troop A on the low band side before MOSWIN was adopted. not heard much traffic on it for a while. Was in Lee's Summit where Troop A headquarters is located last Friday ( 3-11-22) and noticed that the large radio tower behind the building was completely gone! Might account for not hearing low band traffic any more...
