I own both scanners. The Pro-96 is better for digital. I have the digital AGC enabled on the 396 and I can't tell any difference from when it's not enabled. Digital systems come booming in so I have to turn down the volume, then I can barely hear the analog systems. Digital AGC works much better on the Pro-96.
The digital audio quality varies, sometimes the Pro-96 sounds better, and sometimes the 396 sounds better.
The 396 is easier to program and I like the dynamic memory. Maybe I am more used to the Uniden scanners as I own several.
There is one other issue that Uniden has not even acknowledged. If you monitor an EDACS at the same time (in a different bank) as a Motorola digital system, the 396 will stop on those aggravating EDACS beeps for several seconds after a transmission. If you lockout the digital system, it will still transmit the EDACS beeps, but not as often. So if you monitor EDACS and digital, I would go with the Pro-96.
My older Unidens, even the 245 can track EDACS flawlessly, but the 396 cannot.
GTO_04
