plainsmith
- Joined
- Apr 5, 2018
- Messages
- 4
Good day brothers,
Looking to get back into listening to worldwide shortwave, on a Kaito Voyager Pro, currently using a clothesline clip-on antenna.
Have the clothesline loosely hung around living room in L shape...
A: Would having the antenna in a straight line be best?
B: Would running the clothesline out the wall and straight out (like a clothesline) be best?
C: What are the best options a poor electrician could do for a better result?
D: What is 9k -vs- 10k Step, which is best to set this radio at?
Thanks in advance!
Radio being used (and no I cannot afford another right now):
KAITO KA600L 5-WAY POWERED EMERGENCY AM/FM/SW NOAA WEATHER ALERT RADIO WITH SOLAR,DYNAMO CRANK,FLASHLIGHT AND READING LAMP, DIGITAL RADIO WITH LARGER BATTERY AND SOLAR PANEL, SILVER
AM (MW):520-1710KHz
LW (longwave):150-521KHz
SW (shortwave):2,300-23,000 KHz
NOAA Weather:1-7
Internal speaker
iameter 66 mm
Headset jack socket: 3.5 mm
Sensitivity:
FM<10uV
MW<1mV/m
SW < 30uV
Thanks in advance!
AM (MW):520-1710KHz
NOAA Weather:1-7
Internal speaker
Sensitivity:
FM<10uV
MW<1mV/m
SW < 30uV
