A
ACU1000
Guest
I am looking for a single, dual or quad band radio that is also capable of wideband receive in the following ranges: 35-45 FM and 108-136 AM
Anyone got any suggestions?
I thought the term "wideband" meant the channel width, not the total RX coverage of the receiver... FM broadcast stations, TV audio, and things like cordless phones use a wider chunk of spectrum than communications transceivers, which use something like 5 or 2.5 kHz. Every receiver I've heard referred to as wideband has a "Wide FM" mode that can pick up an FM radio station or TV station without distortion. (When you listen to a TV station on a scanner, it's badly distorted. Broadcast FM signals may be so wide that the receiver just sees it as static.)
And don't get me started on "Broadband"....
Hey lemish
The Yaesu VX6/VX7 will do that range. Some so-called wideband HT's don't, like my Alinco DJ-V5 only goes to 76 MHz.
Get a good antenna, that's the key at that freq. Anybody up your way still using 39.50? I know SIRS still gets a lot of use out here in the semi-country but I suspect a lot of that traffic has moved to cellphones in the more metro areas. I still hear corrections on 39.12 also, they do daily radio checks.
See ya back on the VA forum.
The term wideband can be for a receivers total coverage as well as channel bandwidth, it just depends on the context in which one uses it.
I know, but I was referring to gcgrotz's comment, specifically commenting on the radio not being "wide" because it didn't go below 76 Mhz Since that's the lower limit of broadcast FM in some regions, I'm guessing the radio does receive broadcast FM, which is a wideband signal, qualifying that radio as a "wideband receiver."
Sorry - since you did not quote his question I thought your question was "wide banded".
I usually don't bother quoting when I'm replying to the message directly above mine, but I see that some people are narrow enough that they have to have everything handed to them. :lol:
(Sorry... I'm a real stinker sometimes.)
I'm going to ask a dumb question: Have you already monitored this band and determined that there's stuff there you want to listen to?
