Best scanner antenna?
tacalert
PHELAN, CA
Hi peeps. Need your ideas. I've been reading and reading blogs and searching the internet. What is the best base antenna for wide freq scanning receiving no transmitting? I have a clear line of sight for the most part of riverside, ca. I'm using a radio shack pro-2052.
dow35
Reidsville NC
for the price you cant go wrong with the scanttena i tried 3 other antennas and paid twice as much for them before getting the scantenna and it rocks
tacalert
PHELAN, CA
Thanks for the imput. Ive looking and lookin. I'll check it out. Also right now im using rg8x cable but was thinkin of upgrading that as well to maybe lmr400...What ya think
tacalert
PHELAN, CA
I was reading up on the scantenna and found out that They are Ok on 800Mhz,but not great. I mostly listen to 800mhz trunking mode.
