Best sounding speaker for scanning?
doctordave
Anyone have a preference for selection of a speaker for mobile use w/ scanning? I currently have the standard RS model....works OK, but am looking for something w/ even better sound quality....particularly for listening to digital 800.
Thanks much.
Dave
N
N_Jay
Guest
Thanks much.
Dave
I have always liked the '80 and '90 Motorola Mitrek/Micor/Syntor speaker
doctordave
Thanks for the responses. Which vendors might I get these speakers from?
Thanks again.
Dave
N
N_Jay
Guest
Thanks again.
Dave
Look at the surpluss commercial radio vendors, or better yet at Ham Swapmeets.
loumaag
Silent Key - Aug 2014
Katy, TX
doctordave, you didn't say what scanner you were using, so this may or may not apply. Hooking an external speaker to the earphone jack of most scanners will get you less than you hope for. The earphone jack usually has the audio output attenuated so that you don't blow your eardrums out. You can check out various "mods" for various scanners to overcome this on StrongSignals and other sites. :)
KB8UYC
Ypsilanti Michigan
WOW!
I was about to say after 121 post you dont know about MOTOROLA GEAR???
Go to EBAY and look at motorola speakers. You don't really need to Amplified speakers unless you really want to rewire them. Either the Black or the White Motorola speakers will be fine for your application. I use 2 of them in my truck, I acually have a TM-D700A and I have one hooked up to the VHF side and 1 hooked up to the UHF side!
Go with the Motorola speakers you wont be disappointed(not to mention they are relativly CHEAP)
Hope that helps ya
loumaag
Katy, TX
erchambers said:
...I use 2 of them in my truck, I acually have a TM-D700A and I have one hooked up to the VHF side and 1 hooked up to the UHF side! ...
Sounds like you are talking about something other than a scanner, which would be off topic. 8)
KB8UYC
Ypsilanti Michigan
Ok, because I know that your going to do it anyways and you control what is said here....tell me how that is off topic????? so I mentioned another radio, but the question was in reference to SPEAKERS and I recommended Motorola speakers.....
So please dont get on here telling me that I am off topic........
doctordave
Thanks for the replies. I previously had free access to law enforcement-issue Motorola speakers and was tremendously impressed w/ the quality. Mine are 10+ years old now and sounding a little crackly. Will check some surplus equip vendors, since it seems ( from replies) Motorola is still about the best game in town for speakers. Anyone know of an online surplus dealer that it quite reputable? I don't have any experience w/ such vendors.
Thanks very much.
Dave
loumaag
Katy, TX
Okay one thing at at time.
1. I don't control anything.
2. Off Topic:
You will note that the question deals with a speaker for scanning. Your post deals with a Kenwood dual band ham radio, not a scanner (although it does scan), hence off topic. BTW, your TM-D700A has external speaker jacks; have you ever plugged one of those Moto speakers into an earphone jack on a scanner? I have, you would be surprised at how poorly it works.
3. You can ask "please" all you want, but when you wander off topic, don't take offense when your failure to read and understand a thread results on your being "called" for going off topic.
KB8UYC
Ypsilanti Michigan
If you plug a non amplified motorola speaker into a "scanner" that needs amplification then it will sound like crap....ie.....the "PRO-96" needs amplified speakers if you plug one in. Most other "scanners" dont need amplications there fore the motorola speakers will work fine.
Yes I mentioned a TM-D700A there is nothing in this thread mentioning only for scanners. Yes I have TWO MOTOROLA SPEAKERS HOOKED UP TO MY TM-D700A and they work very very well.
I was just using my TM-D700A as an example for the motorola speakers
NOW THAT I HAVE ALL THE MENTIONING ABOUT SCANNERS OUT OF THE WAY TO PLEASE LOUMAGG......
Doctordave.....if you just do a search on EBAY and go to the Motorola section you can buy all of the motorola speakers that you want. They are cheap and work very very well!
loumaag
Katy, TX
It appears that "erchambers" has a problem with me. Okay, but just to keep everything in the open here is a PM he sent me:
erchambers said:
Subject: Your last post reference Motorola speakers
Well, I dont know who you think you are, but I thing that your post was the post that was off topic......you had no right saying what you said and I dont appriciate it. I have never done you wrong and I cannot believe that you would say something like that.
I was not off topic. I simply mentioned that I had Two Motorola speakers hooked up to my radio(so it was not a scanner) there is no rule here that every post has to be about scanners.
And if you would pay attention here you would know that I am deep into scanning and have multiple scanners, so it is odvious that I am a scanner hobbiest.
The post was reference speakers that is what my post was about...so it mentioned another radio oh god forbid.
You are not a moderator here....so stop acting like it, and if you keep posting post like that I am going to start sending them and reporting them to lindsay.
I think you post was a in appropriate.
_________________
Eric Chambers-KB8UYC
R.A.C.E.S/ARES
Washtenaw County Advanced Skywarn Spotter
R.A.C.E.S/ARES Net Control Operator
http://www.michigantrunktracking.vze.com
As for reporting me to Lindsay, if you feel I have been inapproprate, then go right ahead, it is your right to do so. However, don't send threats to me via PM, as you can plainly see, I have no hesitation in letting others see what is said about or to me. :roll:
KB8UYC
Ypsilanti Michigan
ok out of respect loumagg I sent that pm to you......ever heard of PRIVATE MESSAGE????
You are the one with the problem as you keep firing back........By you posting that you have no respect. I did it the right way. I sent you the private message to keep it off of the boards, but you keep firing back at me...
ok, lets get on then
n4voxgill
Silent Key
New Braunfels, TX
When I lived in Orlando my favorite place to shop was Skycraft Surplus. They started out with airplane parts, but now cover everything, including a lot of electronics. I bought a couple of Motorola speakers that were new in the box from them in the past, less than ten dollars. One good thing that one of them a had note in the box that the speaker must be grounded. What a difference it made when I did run a ground. Try them, here is there website
http://www.skycraftsurplus.com/
Gill N4VOX
Mozilla
South Florida
Amplified speaker.
There is a GE -Ericsson speaker that was also amplified and has a on/off switch along with a volume switch. Its even better than the Motorolas... I'll have to dig th part number up. Comes on a swivel mount base and is readily found still new in the box for around $20.
KB8UYC
Ypsilanti Michigan
mozilla.....let us know when you find that part number......sounds like a pretty nice speaker! and for $20.00 you cant go wrong!
Voyager
So replace the actual speaker in the housing with a new one.
Joe M.
N
N_Jay
Guest
Joe M.
THat would probably cost more then just getting an "new" surplus one.
baybum
Howard County
I use a comuter speaker that can handle 9-12vdc input.
Great amplification. I have no problems hearing the radio with the windows down. You won't find anything louder. And they're not expensive.
I keep mine under the front seat.
Mike
