Best USB Audio input devices?
Adenosine
Bangor, ME
After purchasing a few of the Amazon Usb audio adapters that turned out to be junk, I thought maybe you guys already have the answer. I’m going to be using a powered USB hub and need 4-6 line-in adapters for my radios.
What do you recommend for adapters?
belvdr
No longer interested in living
Why not a small USB mixer like the Xenyx series?
w2lie
New York DB Admin
Long Island, NY
I had the same question last year and finally purchased a solution just a month ago. I'm very happy with what I went with. Seems to work exactly how I need it and replaces my old hardware nicely.
belvdr
I'll take any advice, moving everything into a rack and adding some radios. I've run out of audio inputs into the computer.
I have a Xenyx Q802USB. 8 channels in and USB into the computer. Larger models are available.
JSTARS03
Monitor
Sunny Florida
Do the Xenyx Q802USB 8 inputs show up in the Windows Mixer and then Proscan?
I had purchased a Tascam 8 input USB that requires special drivers and special software to use.
So the 8 inputs do not show up in Proscan only DAW software that supports ASIO.
It looks like Phil's does.
Thank you
w2lie
New York DB Admin
Long Island, NY
I was going to ask the same question. How many inputs do you get in Windows? It looks like from the specs, you might only get 2 or require DAW with the Xenyx Q802USB. You need to look at inputs and outputs.
I spoke with someone at Sweetwater and Musician's Friend when I was trying to find hardware and while they didn't fully understand what it was I was trying to accomplish, both of the sales reps suggested staying away from mixer boards and using them as USB input devices. They were both suggesting USB Capture devices like the Scarlett or M-Audio devices.
And you have to be careful when looking out the outputs. Some hardware counts MIDI and other ports we cannot use for scanner audio as inputs to the computer. And even more require additional units to get the full number of computer inputs that they are claiming on the box.
So far, I'm very happy with the Focusrite I purchased. While it is a fortune compared to the cheap USB devices from Amazon, the headache of having the inputs freeze or fail is now gone. (knock on wood). I have 6 independent inputs that I can use for any recording or capture software I need.
belvdr
Thank you
No, this is an analog device. You control everything through the mixer hardware. Some digital mixers can do what you ask, but they get pricey.
Adenosine
Bangor, ME
These are great choices, but dropping $3-400 on it isn’t being realistic for myself. If the answer is the cheaper mixer and if Windows can see the multiple inputs then that seems the likely path. Still we are just talking about streaming scanner audio too, so it surprises me there isn’t a halfway decent usb audio stick out there yet.
Adenosine
Bangor, ME
@w2lie I have been looking at the Focusrite Scarlett 8i6, but I can only see 4 inputs that would be useful for a scanner feed. How did you get 6? I would prefer something rack mounted but, the used 8i6 marked is pretty good.
Edit: OK I think the used ones that were showing were not the 8i6's. The 3rd Gen has 4 inputs in rear and 2 up front.
w2lie
New York DB Admin
Long Island, NY
Correct, 4 on the back and 2 on the front. These come into proscan as stereo ports (1/2, 3/4, 5/6) so you have to pick the input pair then pan hard left or hard right to isolate the channel.
I am noticing that after a reboot, I have to reconfigure the focus rite to allow Windows to see the ports. This means launching feeds after reboot requires some manual maintenance. I have to open a ticket with the FR group to see how I can hard set the configuration to allow windows to access to ports 3 - 6 at all times.
Also, audio sounds great on my end, but some people are saying the audio is low. I don't understand that complaint because audio sounds good to me. I'd like to assume this is a setting on the user end where they have to set their volume higher, but I'm redlining the inputs and when I listen to my own feeds they sound good.
Here are my streams through the Scarlett:
