Best VHF mobile antenna (136-174 Mhz)
neilcarrick
I have a Kenwood TK 7160H and I am wondering which mobile antenna will give the best results. Perhaps also a comparison of magmount and roofmount ? Thanks ..Neil
exkalibur
York, Ontario
You aren't going to find a (practical) antenna that covers 136-174. What primary frequency range will you be transmitting in?
Sinclabs makes a nice wide-band antenna:
http://www.sinclairtechnologies.com/catalog/product.aspx?id=457
It covers 132-174MHz, with 26MHz of bandwidth. This means you could (assuming the radio is to be used for ham radio), 144-170MHz - easily good enough for any LMR applications.
It is also a half-wave antenna, which means you don't need to supply a ground plane. The only mount that is going to give you a good ground is a hole-drilled NMO mount (or similar). Other mounting methods give you a poor ground (lip-mount) or no ground at all (mag-mount), but since this antenna is a half-wave - that doesn't matter - it doesn't need a ground plane at all.
Your other option would be:
http://www.sinclairtechnologies.com/catalog/product.aspx?id=504
This antenna gives you a bit more gain (3dbd), however it requires a good groundplane to work properly, and only gives you 5MHz of bandwidth.
I've always used the 1482 antennas and have been extremely happy with them - they outperform any amateur antenna, hands down. I've used a Comet SBB-7 which claims to have 4.5db of gain, but I can tell you that either of the antennas above will beat the snot out of even a high-end hammie antenna like that.
trooperdude
SFO Bay Area and Las Vegas NV
That all depends on your application.
Are you using repeaters on mountain tops where the high radiation angle of a 1/4 wave is desirable, or is it all simplex in flat terrain where a 1/2 wave or 5/8 wave antenna is more desirable ?
The intended application makes a LOT of difference in antenna selection.
NMO center of roof is always more desirable than a magnetic mount.
Raven95150
Nowthen, MN
Here is what I use for 2 meter and it works great:
http://www.hamstick.com/9007.htm
The only drawback is the length, about 7 feet...not very practical to put on a car but it works great for me, I have it mounted on a Back Rack behind the cab of my truck. It uses a 3/8" CB style mount, so there are many different ways to mount it. If used on a mag-mount, it would have to be one of those big tripod mounts. The bottom half of the antenna is a fiberglass mast and the top half is a stainless steel whip.
