Hi-
I've started piecing together parts for a remote target camera system for long range rifle shooting at 1000 yards. I also want the system to double as a game viewer (mostly at night, to watch hog bait).
I purchased a transmitter and receiver from China. Bad idea. I'll be replacing them, but I figure I need to get quality equipment.
It appears that to have something powerful enough to transmit at 1000 yards, I'm going to need a technician license. At what power level is a technician license required? 1/2 watt? Less?
The equipment options I've found:
2.4ghz: .7w, 1w, 1.5w, 2w
1.2ghz: .7w, 1w, 1.5w, 2w
Antenna options include: 14db yagi or patch @ 2.4, less options at 1.2ghz. 5-9db omni antennas for both
I don't want to interfere with any other radio signals, HAM or anything else. What range would be best for this? I will be only using this at the gun range for a few hours at a time, or in the middle of nowhere on private land (once again for a few hours at a time). I'll be regulated to my battery life (12v 8ah lead acid small boat type batteries). Something to note- on the private land "hog viewing", the signal may need to go through trees, etc.
So what is better to avoid stepping on anyone's toes? 1.2ghz or 2.4ghz? What power level do you think is neccessary out of the unit, and what antennas do I need to get the job done? I'm guessing I need a license for this- is the technician all I need? I've started downloading the material for the test, looks reasonable enough.
I have friends who are interested in something like this- they may not take the time to take the test. Obviously I'll strongly discourage this, after hearing the possible fines. Does the FCC give warnings before fining for a system like above? How do they know how to find someone like this (besides the fact that a target will be on the feed, giving away the location! ha!).
Finally, I've heard there are some systems approved by the FCC that are above the power levels that require a license- how does this work?
