Best way to clear Pro 197 Freqs ?
Arkansas
#1
Fixing to load quite a few new freqs in my Pro 197 and wanted to clear out the memory channels it has programmed now ?
Thank you
73
Kenny
fxdscon
#2
Thank you
73
Kenny
From the owner's manual - page 92:
Turn scanner off-
Turn scanner on again-
Quickly while the "Welcome" screen is showing, press the zero key, and then the 1 key-
Follow the on screen directions.
