I am just wondering what the best Yagi or Directional antenna would be for an SDS200? Is there something small enough that it can fit in my attic and also cover VHF all the up to 900?
Thank you
Thank you
I have a Wilson Electronics 700/800/900 MHz yagi with an N connector and LMR400, it works quite well for monitor local 800 MHz sites. I don't think anyone makes a "all band" Yagi antenna, and if someone did make it I doubt you would actually want to buy it. What exactly are you trying to monitor?
In my experience Yagi antennas are best used for monitoring specific sites/repeaters which can't be easily monitored with an Omnidirectional antenna. They have a specific use case.
Does anyone think a discone would be a good option for me also?
Do you want only signals from one direction or from all around? Yagi's and Log Periodic are directional, they pretty much stink at signals "off center" from where it is aimed. Discones on the other hand don't care what direction the signal comes from, but doesn't amplify (gain) them very much.Interesting how something as simple as a TV antenna will do the trick. Does anyone think a discone would be a good option for me also?
Wut?I would like to pull in signals from all directions
I also was looking at the Diamond 220R today. Looks like a nice antenna and the smaller size is very appealing. I noticed it terminates to a PL259 Connector. I guess I need an Adapter for BNC?
You said you want the antenna in your attic, you want it to receive from all directions.I would like to pull in signals from all directions
