A good pair of studio monitor speakers can be very helpful in the shack.
Good sound with a wide dynamic range can help lift an otherwise non audible signal out of a noisy band.
Those speakers that Zguy has bought are exactly what I am talking about.
To help with the narrow audio range present in most radio communications, may I suggest you try what is now a mostly discarded piece of technology.....A Graphic Equalizer!
They can be had very cheaply nowadays- as nearly everyone relies on Dolby surround or other digital processing.
An equalizer in the audio path BEFORE the P.C. soundcard input can greatly help reduce hiss, CTCSS hum or just plain noise like that on the HF bands which can make for some really good quality recording that still sound natural. DSP can sometimes produce nasty artifacts that can spoil a recording.
An old analog graphic equalizer can be just the thing for cleaning up noisy audio.
Here is my little audio "mastering module" which was quite cheap to setup, with mostly older Radioshack branded equipment.
The venerable Minimus 7 speakers, Realistic 10 band graphic with "cool LED spectrum display" and a small Realistic SA-10 amplifier. An Autek QF-1A audio filter (an awesome piece of gear) helps to clean up the HF audio. A Psyclone multi input "gamer console" switcher is used to switch between radios and even has a remote control.
Grab those studio monitors and an equalizer! You will be pleased at the results!
Commscanaus
