Better scanner antenna for 800 MHz systems
ASU93EF
I have a Uniden Bearcat BCD325P2 and live in the Fort Worth area. I listen to several different sites on the Fort Worth Regional Radio system. When I am in my car, I miss some radio traffic. For example, I will hear dispatch tones set off for fire callouts, but don't hear the voice dispatch. Then I will hear the tail end of the dispatch or units checking enroute.
Is there a better rubber duck style antenna that picks up the 800 MHz systems? That's really all I listen to, so I don't need a broad spectrum antenna. I have tried the Harulu double antenna, but it wasn't any better.
Thanks in advance!
Eric
hardsuit
Vrigo Super Cluster, Milky Way Galaxy, Sagatarious
Radio Shack telescoping CENTER loaded HAM antenna is the BEST Scanner I have ever used , its 6" closed for 800mhz but it can also extent to a full 26" for CB and VHF AIR / VHF Marine as well.
however, in a CAR any Whip or Rubber Duck antenna is not efficient, you really need a Window Clip mount (external) or a External Mobile Mount antenna for BEST reception. Radio Shack used to make a MOBILE mount antenna the SAME as the Hand Held one with a Center Load and Telescoping Sections.
TailGator911
Silent Key/KF4ANC
Fairborn, OH
Yep, the Remtronix 800mhz antenna is the way to go. Marketed under several names, I believe Remtronix is the actual original manufacturer, but I could be wrong. The Rat Shack put their name on it in their stores, as did other dealers. Best 800mhz duck ever made. I use it with a window clip mount on my truck and it works great.
JD
kf4anc
