- Joined
- Nov 6, 2021
- Messages
- 3
Forgive me if this isn’t the right sub to post under it’s the only one i found that was close.
Ever since Bexar went P25 PII and mostly encrypted you haven’t been able to listen on a scanner except little blips here and there and Fire Dispatch. You were however able to listen to individual talk groups over AARRS and create a playlist on Broadcastify. Now it seems the ability to even listen to individual talk groups has been taken away as of last month, whenever you go to the talk groups it says “This talkgroup was last seen: 2025-06-24T07:53:13-05:00”.
Does anyone know if these talk groups will be coming back, if something happened to the host of them, or if everything is completely gone now and only able to listen to fire dispatch via scanner & Broadcastify? I’m assuming at some point there will be nothing left to listen to here in Bexar at this rate.
Being able to listen to the fire grounds was nice while it lasted.
Appreciate the input!
