I don't see that. I see a DLL that's 242,925 bytes? It's probably fine, but it's not 119,296 bytes."You have to be using a version of rtlsdr.dll that supports bias tee control. Looks like its size is exactly 119296 bytes. "
I see that version (size dll file) is contained in the Bias T driver linked in post #4...
Curious, So did the '-T' option work in FMPP for your SDRDuo?im using the SDRDuo I think iv found it
-T<num> Enable/disable RSP2 bias tee (0-1) [-T0]
no I could'nt get mine to work, im using a Nooelec LaNA when I press the -T no LED lights up on the LaNA, this a shameCurious, So did the '-T' option work in FMPP for your SDRDuo?
The help from FMPP which you show only mentions the 'RSP2'. If it doesn't then this could be one of the limitations of the driver which maybe useful for others to know.
FMPP does not seem to have a keyboard shortcut to enable/disable bias tee once it's enabled via command line (-T1).no I could'nt get mine to work, im using a Nooelec LaNA when I press the -T no LED lights up on the LaNA, this a shame
Maybe, I don't ever use the RSP1A with DSD+ myself and I don't have an LNA as I live inner city where signals are quite strong so bias tee is not needed.Sounds like the developers don't have 1A's or Duo's to work with. Maybe you could collaborate with them. The worst they can say is no.
