Big Problem
Mrbadness
Port Charlotte, Florida
#1
I'm using Proscan software to program my scanner and when I disconnect the cable the scanner shuts off and won't start up. when i connect back up to the computer it works again. Can't figure it out. can anyone help
iMONITOR
MACOMB, MI.
#2
What scanner? Serial port, or USB port? Are you shutting down the software before disconnecting the scanner?
KC1UA
Scan New England Guru
Cape Cod, Massachusetts
#4
Sounds like a portable scanner that is powered by the USB connection and either has dead or no batteries installed. Just taking a guess based on the vague info.
