I would be surprised if you didn't see an impact to reception regardless. Radiowaves can impact radiowaves, especially if close to the reception/transmission points. bluetooth seems to use unlicensed frequencies in the 2Mhz range, or 2Ghz range, I'm no engineer, but I suspect they are within the ranges to cause harmonic/anti-harmonic reduction or cancellation with radio frequencies.
