Bluetooth for G4/G5?
JD21960
ILL-annoyed
BT for G4/G5
That one for Unication by ScannerMaster has A beep. I remember someone saying so after we all discussed this last time. He said it does have a tone... but it's a short one. The quote is in the search box somewhere.
6Paul21
Florida
I just received the G5 and want to use my Bluetooth with this unit. Could someone please let me know how to set up the G5 to pair.
Thanks Ed
krokus
Southeastern Michigan
Thanks Ed
Assuming the menu is the same as the G4, on the Function Status menu, turn on BT Device and Earphone.
Is your speaker/headset/earpiece BT 3.1, or earlier, compatible? The G4, and I presume the G5, will not pair with BT 4.0 and newer.
Sent via Tapatalk
ecarvalho
Hello Ed
G5 and G4 are identical except for the dual band on the G5. Bluetooth yes Krokus explained above will not pair to newer BT devices and beware of the beeping and announcing voice some devices do. Each transmission might start with it and that will get old fast.
Some bt devices work better than others.
6Paul21
Florida
I am searching for a BT ear piece to pair with G5. The Plantronics M50 is discontinued. I want one without all the ding and dongs before a transmission.
Thanks Ed
mswells
WB6JLB
Phoenix, AZ
I am using the Docooler 2 in 1 Bluetooth receiver, and am getting frequent disconnects. The receiver is sitting right next to the G4, and is plugged into usb for a constant charge. Is there a setting to change in pps to keep it from disconnecting, or is it just the receiver issue itself ?
mswells
WB6JLB
Phoenix, AZ
Humming Sound and Disconnects
I am also hearing a humming sound under the audio !! I tried it out on my Broadcastify Phoenix Police feed, and was hearing a bad humming with the audio.
krokus
That is a "feature" of the pager. It treats every received bit as a new phone call, which is to try and save battery life. I have asked if there is a way to have that user defined.
Sent via Tapatalk
JD21960
ILL-annoyed
Bluetooth for G4/G5 pager?
@MsWells ... I noticed some of the reviews from the Docooler BT transceiver saying they got frequent dropouts. After having mine for awhile it started doing that with a loud static/clicking sound. Trying to restart it to connect I would get a loud phone call ringing sound. I then read it was a battery saving feature of the pager. Ok? So to beat it at it's own game I turn the G5 "SCREEN TIMEOUT" time to 05 or 06 seconds. THAT saves the battery throughout the day. One time I achieved over 15 hours using that battery saving, screen off feature. During that time the Docooler never dropped out once until it finally ran out of juice itself after it's time limit of 8 hours. I would try that if you're having dropouts where it's right next to the Pager. Use the Screen timeout feature on the Pager and experiment.
Bluetooth gaming headset Yo David!!!!
Hey on the Unification G4/G5 Bluetooth headset issue, in theory wouldn’t a Bluetooth gaming headset work because a gaming headset would have 0 setting pertaining to calls? Let me know your thoughts.
Anyone else have a recommendation on a Bluetooth headset or earpiece?
Is this adapter battery operated? Rechargeable the amazon listing doesn’t show a picture of the back or say whether it is.
ResQguy
Meh
Yes it does. "Battery: Built-in Rechargeable Li-polymer battery(600mAh)
Working Time: 8 Hours (depend on audio volume)
Charging: Micro USB 5V/0.5A"
APX8000
Sarcastic Member
AES-256 secured
Also...
These work without any beeps / announcement voices or rings:
Docooler 2 in 1 Bluetooth Transmitter & Receiver Wireless A2DP Bluetooth Audio Adapter Portable Audio Player Aux 3.5mm Black https://www.amazon.com/dp/B01FDI8VBI/ref=cm_sw_r_cp_api_PwLxzbDFPSQQD
Hmmmm....since it has a 3.5mm jack, I’m wondering if anyone has tried pairing it to this device and then running a Kenwood KES-3S 5W external speaker from the 3.5mm jack? Thoughts?
APX8000
Sarcastic Member
AES-256 secured
I’m going to give it a try. Will post results once I get everything in and hooked up in the car.
