Really tough to tell from that pic, but this is probably it:does anyone know what kind of wrench is needed to remove this panel nut on the outside of the BNC connector? the scanner is a pro-2030
Yea. I think the forum de-res'ed the picture a bit when I uploaded it or b/c I cropped out so much.
a417, do you mean snap-ring pliers. I have a few of those. I did not think to try.
fxfscon. that X-key sounds familiar. I know it was mentioned once on an episode of Scanner guys, but I could not remember which one.
I will try a pair of snap-ring pliers first.
Heard them called both names, the antiques I have are engraved with "spring clip remover". @CycleSycho is right, they usually have right-angled inserts that make it infinitely easier to use.do you mean snap-ring pliers.
