BNC type antenna to the SMA antenna jack
SoCalSearch
Does anyone make any type of high-end, machined connectors?
Looking for the highest quality available to fit on a Yaesu FT3D
Any guidance would be appreciated
Thank you
FedFyrGuy
Hagerstown, Maryland
These will work - plenty of others available online I'm sure.
If you were going to use the radio in a portable or desktop setting, I would have suggested an SMA(M) to BNC(F) coax short length whip.
Good luck!
Pasternack. Cables, Coaxial Cable, Cable Connectors, Adapters, Attenuators, Microwave Parts
SMA Male to BNC Female: SMA Male to BNC Female Adapter
SMA Female to BNC Female: SMA Female to BNC Female Adapter
They'll have good stuff, not Chinese junk. But since you said "highest quality", you know it won't be cheap.
Personally, I'd find something a bit less expensive.
Sporrt
Chicago
I'm using a Diamond BNCJ-SMAP adapter, with a Diamond RH-77ca antenna,
on my Icom ic-t70a.
Seems pretty solid, noticeable improvement on 440 MHz.
