Bonito e-field antenna
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
There's an article on the SWLing.com website reviewing the Bonito e-field antenna, the MA305
Brilliant hard-core DX with the USB-powered Bonito MegActive MA305 antenna | The SWLing Post
and as for the antenna itself...
https://hamradioshop.net/en/Antennas/MegActiv-MA305-Active-Antenna.html
Being an e-field antenna, you need to be in a real quiet area, able to put the antenna a good distance from the home (like a rural setting) to use this antenna effectively. Otherwise you may hear a lot more noise than signal.
Mike
prcguy
I see to things that concern me about this antenna. First is its powered by USB and that can couple RFI from a computer into the antenna. I think computers and VLF/HF antennas should be separated as far as possible to avoid problems.
The second thing is the current consumption is only 10ma @ 5V, putting it at the low end of surviving in a high RF area and it probably overloads and creates IMD very easily. Higher performing active E-field antennas usually run from 12 to 24V and consume 50 to 100ma, which is needed to bias and run the larger transistors which will operate in high RF environments with no IMD.
prcguy
Mike
