Bossier Parish Sheriff TRS???
milf
Careful, I CAN hear you!
Indianapolis, IN
OK guys N Gals, is this system still active? Is BPSO still using it, or have they moved fullly to the LWIN? Have not had any data since 2008 on it so its high time to take a look. All we ever got for it was the dispatch TG...
Also: On the Parish 911 Repeaters, they are fully Licensed for DMR (TRBO).. Have they switched over to DMR usage on the VHF repeaters?
154.3400
155.5500
155.2650
155.7675
