BR330T priority question
bfeeny
Royal Palm Beach, Fl
When I stop on a channel in a system, is there a quick way to turn Priority on for that channel? I realize Func+PRI sets the priority mode of the scanner (PRI on, PRI off, PRI Plus On), but I just want to turn on priority for the channel without having to go back thru Menu->System->etc->etc
Brian
bfeeny
To follow up on my own question, I see the BR330T only supports Priority of conventional systems......the channel I had in mind is trunked, so I guess thats out. in any case, even for conventional channels, if there is a quick way to enable/disable priority of the channel it would be great to know, thanks.
Brian
